CONFIG FOR CISCO AS A PSTN GATEWAY
Discussion in '3CX Phone System - General' started by mraxa, Jan 2, 2012.
  1. mraxa
    Jan 1, 2012
    I have having some issues while registering a virtual extension used for PSTN gateway. I am using Cisco 2800 Series Router including 4 Port FX0 Card. I shall be using a PSTN Line for testing purpose. IP address being used for 3cx is 10.200.3.14 while Cisco Router that will be acting as a PSTN Gateway will be on another Subnet i.e 10.200.6.0 / 24. IP address for Router is 10.200.6.20 / 24. I tried to register Sip server but it failed and recieved an error for Authentication failed which is mentioned below. I've checked and verified the password twice and thrice but still the issue persists.
    22:10:58.658 [CM102001]: Authentication failed for SipReq: REGISTER 10.200.3.14:5060 tid=22582 cseq=REGISTER contact=.10000@10.200.6.20:5060 / 149 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    CONFIGURATION AT ROUTER :-voice class codec 1
    codec preference 1 g711ulaw
    codec preference 2 g729r8 bytes 40
    codec preference 3 g723r63 bytes 96
    codec preference 4 g726r16 bytes 80
    voice-port 1/0/0
    no battery-reversal
    timing hookflash-out 50
    connection plar opx 999
    dial-peer voice 20000 voip
    preference 1
    destination-pattern 99.
    voice-class codec 1
    session protocol sipv2
    session target ipv4:10.200.3.14
    dtmf-relay rtp-nte
    no vad
    dial-peer voice 10000 pots
    destination-pattern .T
    port 1/0/0
    sip-ua
    authentication username 10000 password 091D1E594955
    retry invite 3
    retry response 3
    retry bye 3
    retry cancel 3
    timers expires 300000
    registrar ipv4:10.200.3.14 expires 300
    sip-server ipv4:10.200.3.14:5060
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    It's interesting. I always thought it is either proprietary (i.e. possible with Cisco Call Manager / Cisco UCM only) or H.323 based / incompatible. Also ISDN BRI/PRI ports could be useful, if eventually open SIP standard based.
    Only former Linksys (now Cisco) seems be standard based and supported.
    Regards
  3. Wanderer
    Nov 9, 2010
    19
    I briefly experimented with a Cisco 2611XM and found the same problem, I discovered if you select "Do Not Require" under
    "PSTN Devices" select gateway, go to Advanced tab.
    Once I completed this the Cisco would show as registered and I could make calls.
    I hope this helps.
  4. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    I have had success with earlier versions of 3CX by setting the gateway Source Identification as follows:
    Contact: Host Part Custom Field IP Address:port of Cisco Router
    This no longer works with more current versions. Instead configure the Cisco Router as a VOIP Provider/Generic SIP trunk in 3CX. Then on the Source ID tab select the box “Source Identification by DID”. Leave the default setting for the SIP Field containing DID numbers as “Request Line URI: User Part. Then add a mask for Source Identification by DID that will include all your incoming dialed numbers. Once this is done 3CX will no longer request the Cisco Router to authenticate.
    Mark
  5. new29
    Apr 12, 2012
    11
    This works fine and inbound calls work. However, outbound PSTN calls fail. Any additional tips?
  6. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    New29,
    Not sure what error you are getting on your outbound calls, however here are the outbound settings I use successfully with 3CX.
    Mark
  7. gregja1310
    Apr 19, 2017
    7
    Anyone here can assist in getting a cisco 2800 to work with t1 ?
