Config Issue for Patton 4114 FXO
Discussion in '3CX Phone System - General' started by bdasari, Feb 25, 2013.
  1. bdasari
    Feb 25, 2013
    Hi All,
    Starting installing Patton 4114 FXO, can ping the box but 3cx is not communicating with it. No VOIP led light lit.
    1970-01-01T00:11:12 : LOGWARNING : Config: % ^ Keyword mismatch
    1970-01-01T00:11:12 : LOGWARNING : Config: Line 219: SN4114/JO/EUI(ctx-cs)[switch]#registration-lifetime 300
    1970-01-01T00:11:12 : LOGWARNING : Config: Line 220: SN4114/JO/EUI(ctx-cs)[switch]#registration manual 172.20.57.1
    1970-01-01T00:11:12 : LOGWARNING : Config: Line 221: SN4114/JO/EUI(ctx-cs)[switch]#user 10000 authenticate name 10000 password 10000 default register
    1970-01-01T00:11:13 : LOGWARNING : Config: Line 223: SN4114/JO/EUI(ctx-cs)[switch]#gateway sip GW_SIP_1
    1970-01-01T00:11:13 : LOGWARNING : Config: % ^ Keyword mismatch
    1970-01-01T00:11:13 : LOGWARNING : Config: Line 226: SN4114/JO/EUI(ctx-cs)[switch]#gateway sip GW_SIP_2
    1970-01-01T00:11:13 : LOGWARNING : Config: Line 227: SN4114/JO/EUI(ctx-cs)[switch]#call-signaling-port 5064
    1970-01-01T00:11:13 : LOGWARNING : Config: Line 228: SN4114/JO/EUI(ctx-cs)[switch]#bind interface IF_IP_LAN router
    1970-01-01T00:11:13 : LOGWARNING : Config: Line 230: SN4114/JO/EUI(ctx-cs)[switch]#service default
    1970-01-01T00:11:14 : LOGWARNING : Config: % ^ Keyword mismatch
    1970-01-01T00:11:14 : LOGWARNING : Config: Line 231: SN4114/JO/EUI(ctx-cs)[switch]#domain 172.20.57.1
    1970-01-01T00:11:14 : LOGWARNING : Config: Line 232: SN4114/JO/EUI(ctx-cs)[switch]#defaultserver manual 172.20.57.1 loose-router
    1970-01-01T00:11:14 : LOGWARNING : Config: Line 233: SN4114/JO/EUI(ctx-cs)[switch]#registration-lifetime 300
    1970-01-01T00:11:14 : LOGWARNING : Config: Line 234: SN4114/JO/EUI(ctx-cs)[switch]#registration manual 172.20.57.1
    1970-01-01T00:11:15 : LOGWARNING : Config: % ^ Keyword mismatch
    1970-01-01T00:11:15 : LOGWARNING : Config: Line 235: SN4114/JO/EUI(ctx-cs)[switch]#user 10001 authenticate name 10001 password 10001 default register
    1970-01-01T00:11:15 : LOGWARNING : Config: Line 237: SN4114/JO/EUI(ctx-cs)[switch]#gateway sip GW_SIP_2
    1970-01-01T00:11:15 : LOGWARNING : Config: Line 240: SN4114/JO/EUI(ctx-cs)[switch]#gateway sip GW_SIP_3
    1970-01-01T00:11:15 : LOGWARNING : Config: Line 241: SN4114/JO/EUI(ctx-cs)[switch]#call-signaling-port 5066
    1970-01-01T00:11:16 : LOGWARNING : Config: Line 242: SN4114/JO/EUI(ctx-cs)[switch]#bind interface IF_IP_LAN router
    1970-01-01T00:11:16 : LOGWARNING : Config: % ^ Keyword mismatch
    1970-01-01T00:11:16 : LOGWARNING : Config: Line 244: SN4114/JO/EUI(ctx-cs)[switch]#service default
    1970-01-01T00:11:16 : LOGWARNING : Config: Line 245: SN4114/JO/EUI(ctx-cs)[switch]#domain 172.20.57.1
    1970-01-01T00:11:16 : LOGWARNING : Config: Line 246: SN4114/JO/EUI(ctx-cs)[switch]#defaultserver manual 172.20.57.1 loose-router
    1970-01-01T00:11:17 : LOGWARNING : Config: Line 247: SN4114/JO/EUI(ctx-cs)[switch]#registration-lifetime 300
    1970-01-01T00:11:17 : LOGWARNING : Config: % ^ Keyword mismatch
    1970-01-01T00:11:17 : LOGWARNING : Config: Line 248: SN4114/JO/EUI(ctx-cs)[switch]#registration manual 172.20.57.1
    1970-01-01T00:11:17 : LOGWARNING : Config: Line 249: SN4114/JO/EUI(ctx-cs)[switch]#user 10002 authenticate name 10002 password 10002 default register
    1970-01-01T00:11:17 : LOGWARNING : Config: Line 251: SN4114/JO/EUI(ctx-cs)[switch]#gateway sip GW_SIP_3
    1970-01-01T00:11:20 : LOGINFO : Warm start.
    Any advice please.
    Regards,
    Bala
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Did you upload the config generated by 3cx?
  3. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    This is a pretty good place to start ... http://www.3cx.com/voip-gateways/patton-smartnode/
    There is some fine-tuning you can do after the install - but following these instructions should get you making & taking calls.
    best regards ...
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You may also want to change the loop back rate to 200ms its configured by default in 3cx for 60ms. Hope this helps.
  5. cfive
    cfive Member
    Aug 20, 2009
    284
    Is loop back rate a location (country) specific setting?
    Also, I haven't checked lately but the 3cx config was setting the patton NIC to 10/half duplex, when I see no reason not to set it to either match the switch or to auto?
    Thanks, Les.
  6. jpillow
    Jun 20, 2011
    1,342
    Not country but carrier from what I understand with that being said i have to change on every install ive done using Pattton, thoughg its an easy change and other than that no issues.
  7. AlecM
    Aug 24, 2007
    52
    I've been using a Patton SN4114 FXO for several years with software v R4.2.
    I decided it was well overdue to get updated to R6.3 as this recently came out, and seems to be the firmware version that the 3CX templates know about.
    I backed up my running config and uploaded the new firmware.
    I restored my config, but the Patton will no longer register with the 3CX server (I'm running v11 SP4 Pro, licenced for 16 calls).
    I tried using the Gateway creation wizard in 3CX, but this does NOT provide an option to download/generate the config file for pushing to the Patton box, contrary to what the config guide at http://www.3cx.com/voip-gateways/patton-smartnode/ indicates should happen.
    I am now stuck with no PSTN lines! Major problem.
    I suspect the new firmware uses a different login process and the old config file could not supply all the right details, but the user manual for 6.2 is (like the Patton admin pages) very difficult to understand.
    I cannot find anywhere to check on the Patton admin pages about setting the 3CX virtual extension password. The closest I've found is a Call Router Mapping Table Function for e-164 to the virtual extension numbers (10000, etc), but there's no password field associated with this.
    Any help would be greatly appreciated.
    Regards,
    Alec
  8. seetarc
    Aug 29, 2008
    45
    I had this issue. The old template 3cx template that was applied to the 4114 does not work with the new firmware. What i did was regenerate the new template in 3CX v11 with 6.x firmware in and use text to edit the extension, password to match what was on the 4114 and apply the new config to the 4114 and it worked
  9. AlecM
    Aug 24, 2007
    52
    Hi Seetarc,
    How did you generate the template file? I don't get the button for "generate" after re-running the new gateway wizard. It creates the virtual extensions, new passwords, etc., and shows the summary page, but then just stops at there.
    I should add that I have now restored 4.2 and reloaded my config to get it working again.
    I have also logged a support ticket with Patton as they offer free lifetime product support.
    Al
