config issue
Discussion in '3CX Phone System - General' started by GBond, Feb 3, 2016.
  1. GBond
    Nov 27, 2011
    12
    Testing SIP Port 5061 using STUN server: stun.3cx.com:3478
    Resolving STUN server stun.3cx.com ... Resolved to: [198.50.247.220]
    [Test1] Reachability test ... Resolved Public IP: 80.5.219.64:5061
    STUN server stun.3cx.com has second address 198.50.247.219:3479
    [Test2] One on One Port Forwarding ... FAILED.
    No response received or port mapping is closed. Firewall check failed. This configuration is not supported
    Testing Tunnel Port 5090 using STUN server: stun.3cx.com:3478
    [Test1] Reachability test ... Resolved Public IP: 80.5.219.64:5090
    [Test2] One on One Port Forwarding ... OK.
    can some tell me what I have got set wrong?
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    133
    I would say, Sip Port 5061 has not been configured on the firewall
    http://www.3cx.com/docs/firewall-router-configuration-voip/
  3. leejor
    10,366
    227
    Have you chosen to use port 5061, instead of 5060, for some reason?
  4. GBond
    Nov 27, 2011
    12
    Yes have set to 5061
    & firewall is configured as far as I can tell
    I think my cisco spa232d uses the 5060 port
    if it is a firewall issue what can it be it ok on port 5090? & port 5061 is set up the same?
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    You can't use 5061 as the SIP port because it is used for Secure SIP and is hard-coded. Try using 5059 if you cant used 5060 instead and see how that goes.
  6. GBond
    Nov 27, 2011
    12
    If I change to a different port (5059) the firewall checks out "ok" until I start adding my sip phones back on to that port that I get the same error is this correct? (have to set them to that port other wise they do not register)
    It does now go on hook but still shows as disconnected when not on local network any idear why this is?
  7. NickD_3CX
    Jun 2, 2014
    1,255
    63
    I assume you are talking about a 3CXPhone app.
    Try making a call and see if it gets connected. If it does, the 'disconnected' night refer to the Presence information, in which case I would recommend having a look at this forum thread:
    viewtopic.php?f=34&t=43819&e=1&view=unread#unread
  8. GBond
    Nov 27, 2011
    12
    Thanks that does make some sense I have also found that ISS can only be used on 80 443 ports which I already have in use
    I am now deciding what I wish to do to resolve this but at least I now know what the issue is
    Regards
    Garrath
