- Joined
- May 25, 2012
- Messages
- 2
- Reaction score
- 0
Hello, I'm configuring my first installation of 3CX. The basic installation went OK, but I'm confronted with the following challenges and I can't see the
1) 3CX is on the DMZ and Microsoft Dynamics on the LAN, so I need to know what ports need to be open between the two. The document that tells which ports are in use assumes LAN/WANconnection to 3CX only.
2) I nearly got my Cisco 7490 IP phones working, but then I couldn't see how 3CX and the phones work together, with the TFTP folder and everything. I'm knowledge deficient wrt SIP functionality, but my Asterisk box only needs a single file for the Cisco in its TFTP folder, but the 3CX document suggests two files, unless I'm reading it wrong.
3) Finally, I don't understand how the Dynamics plug-in works. If I'm using physical SIP phones what's the purpose of 3CX MyPhone, and how does it impact Dynamics and how does it work with SIP phones?
My ISP Entacall uses 5060 TCP and UDP, and also 10000-20000 TCP/UDP. The 5060 bit I understand, but how does 3CX use 5090 and how do you recommend that this and the 10000 ports are translated at the firewall (SonicWALL TZ100W). I see from the list of ISPs that Entacall is there and works with the template.
Any help with these issues much appreciated.
Dermot
Dermot
