Configuration Download
Discussion in 'Ideas' started by MattPridd, Oct 30, 2017.
Configuration Download 5 5 4votes
5/5, 4 votes
  1. MattPridd
    Oct 30, 2017
    Hi guys,
    It would be really handy to add the ability to download an extensions configuration file (the one that comes with the welcome email) direct from the Extension on the Management Console. Currently I believe the only way to get the config for testing is to over-type their email, then temporarily use your own and swap back,
    Thanks in advance!
    Silly English Kniggit likes this.
  2. Silly English Kniggit
    Sep 13, 2017
    220
    89
    YES PLEASE!! Having to change the email address to mine just to get the file is not good, and forgetting to change it back is even worse.
  3. Florian87
    Mar 11, 2018
    I really need this function. We often have extensions, that do not have a email-address assigned.
    Please just make a download link for admins on the portal.
