Configuration for Soho66 SIP provider
Discussion in '3CX Phone System - General' started by IMVISH, Oct 19, 2013.
  1. IMVISH
    Oct 19, 2013
    I am new to the VOIP systems
    We have VIOP service from http://soho66.co.uk, can some one guide me how to configure 3cx system? or what details I should ask from them?
    we have 2 numbers with them.
    if you require any further details, I can provide
    Please help.
    TA
  2. Cjay
    Cjay New Member
    Feb 24, 2007
    199
    Not sure which bit you are stuck on but I have Soho66 working fine here (I have 1 incoming number) so it is 3cx compatible.
    Are you at the point that the Soho trunk is registering?
    You should have been given by Soho66 (probably by email) details of (1) the SIP registrar server, (2) your VoIP Username & (3) Password. If you create a new VoIP provider in 3cx (using any of the provider templates) then in the SIP server hostname you can enter (1) and in the Account Details you can enter Authentication ID (2) & Authentication password (3).
    If you are past this point but still struggling then more information will be needed on your configuration and what problems you are seeing.
  3. IMVISH
    Oct 19, 2013
    Hi Cjay
    thanks for the reply,
    I have now managed to register the trunk.
    will have to now learn the configurations :):):)
    Kind regards
