Configuration Nokia E65
Discussion in '3CX Phone System - General' started by mloggen, Jun 3, 2007.
  1. mloggen
    Jun 3, 2007
    does somebody know the configuration for the Nokia E65 and 3CX ??
  2. abercoms
    May 3, 2007
    12
    Create an extension in 3cx for example "100" and password: "100"
    after that enter the settings in your phone
    1. Go to "Tools" and then to "Settings"
    2. Go to "Connection"
    3. Go to "SIP settings"
    4. Add a new default profile
    5. enter the following settings:
    Profile name: 3cx
    Service profile: IETF
    Default access point: choose your WLAN access point
    Public user name: your extension@ip from your 3cx-server (Example: 100@192.168.1.1)
    Use compression: No
    Registration: Always on or When needed
    Use security: No
    Proxy server:
    Proxy server address: ip from your 3cx-server (example: 192.168.1.1)
    Realm: 3CXPhoneSystem
    User name: your extension (example: 100)
    Password: the password of your extension
    Allow loose routing: Yes
    Transport type: UDP
    Port: 5060
    Registrar server:
    Registrar serv. addr. : ip from your 3cx-server (example: 192.168.1.1)
    Transport type: UDP
    Port: 5060
    Now go back to "Connection" and then to "Internet tel. settings"
    create a new profile:
    SIP profiles: 3cx
    And then it works
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    223
    Thanks abercoms!!
  4. ebiemans
    Jun 18, 2007
    Thanks, these settings also are useable for the Nokia E60 with Firmware v3
    I'm almost there, for some reason the 3CX PBX does see the Nokia as an external device
    1. I cannot receive calls, I do receive missed calls
    2. Trying to call external via Voip buster I get an entry in the log file
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.122.2'; From: 'thisis'; To: '0031XXXXXXXXX'; Rline: '0031XXXXXXXXX'; Contact: '100'
    And when I enable the feature Use "IP in 'Contact' to recognize source"
    IP Range : 192.168.122.2
    Calls from the Nokia E60 are seen as inbound calls and are not routed to Voipbuster but to an internal number as specified for inbound calls coming from Voipbuster.
    -> With the 3CXPhone (softphone) everthing works fine
    Thanks for your help
    3CX Phone System Version3.0.2295.0
  5. JT
    JT
    May 5, 2007
    How to transfert a call with NOKIA E65 ?
    Thank you very much for these settings.
    My Nokia E 65 is now a very good intern and extern phone.
    I have just a problem : I don't know how to transfer a call to another extension ...
    Do you know how to do that ?
  6. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    Will this work on a E-62?
    Do you know if this will work on a E-62 also?
    It has the SIP connections in it.
    Most of the settings are the same.
    But I do knot know the hardware difference in a E-60, E-62, or a E-65.
    If anyone knows let me know.
  7. rodneyeid
    Aug 8, 2007
    18
    Incoming not working
    guys i used the settings you offered herefor E65, i managed to get the profile registered at last (thanks to your help) but my only problem is that i can call out! but i cannot recieve calls. any settings i shoudl do from server
  8. simones181170
    Dec 4, 2007
    51
    no way to configure my e65 with 3cx
    i'm trying wiht Fring,
    in fring there are to configure user, pass, and server
    for the server i tryied to use the local ip - but don't work
    if i put the domain or the ip of the domain the E65 connect as Ext
    but i recive incoming call and can make call to the other Ext, but i can't make outgoing call
    any idea!!!!!!!!!
