Configuration of 3CX with Netcomm Smart Voice V422
Discussion in '3CX Phone System - General' started by prabjeet, Oct 10, 2010.
  1. prabjeet
    Aug 19, 2009
    Hi Everybody,
    I am trying to configure 3CX with Netcomm V422 voice gateway. Has anybody ever tried this before or can help me configuring this??
    Thanks in advance
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    This is not directly supported by 3CX. However, 3CX permits you to setup a Generic gateway. You might want to try that, but if there are problems once you have licensed 3CX, you might find support somewhat limited.
    Outgoing calls should be straightforward enough. With incoming calls you need to tell the gateway where to send them, usually the internal trunk number on 3CX. Check out some of the supported gateways to get an idea of how to best configure it.
