- Joined
- May 25, 2018
- Messages
- 22
- Reaction score
- 11
Good Day,
it would be great to have a user creation based on templates.
Example:
On extension - add extension you get a selection of templates with customized settings.
In this templates you can define forwarding rules, exteptions and options for recording and so on.
I know you can select more than one extension and can do by this way bulk configuration but this is only OK till 50 extensions. For big installations not.
Also copy of an existing extension would be fine (i think this is in progress!?).
Example:
Upvote
26
