COnfiguration with messagenet
Discussion in '3CX Phone System - General' started by Avilla, Jul 6, 2007.
  1. Avilla
    Jul 6, 2007
    9
    Hello everybody,
    has anyone already realized a stable connection with the Italian provider Messagenet ?
    Thanks a lot
    Credo che qualch'uno in un altro thread ha consigliato questo provider, ma io non sono ancora riuscito ad avere un collegamento funzionante
    Mille grazie
  2. marmac
    Jun 17, 2007
    6
    Messagenet.
    Con queste impostazioni funziona tutto.
  3. Avilla
    Jul 6, 2007
    9
    Thanks for the prompt reply.
    I have still some problem: I can hear sound, but my sound is not trasmitted, but in a way locally echoed. Would it be a problem with the STUN server. In the general setteing a STUN server is specified by default..
    Ti ringrazio per la celerit
  4. marmac
    Jun 17, 2007
    6
    Messagenet
    I've tested configuration of MESSAGENET with SoftPhone (many) and Siemens VoipPhone both of them used as extension on LAN.
    Please post type and lan configuration of your phone(s)....
    Probably is a NAT or ROUTING problem.....
  5. Avilla
    Jul 6, 2007
    9
    Yes you are right :D
    now I am working with our firewall and I see some improvements
    many thanks
