Configurations for SPA3102
Discussion in '3CX Phone System - General' started by miraportuga, Aug 17, 2007.
  1. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Anyone kind enough to post here the configurations for this device? Coz i cant make any calls at all.
    Thank you
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please find the setup guide as below:
    http: //www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Thats what i did, still cant receive or make calls... everything else works fine on 3cx phone system, except this... :|
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Have you done the outbound rule configuration for this device?
    Please provide the system log for us as well. That maybe help to fixed your issue faster.
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Links below for my working configuration:
    http://www.ezvoip.ca/ezshare/SPA3102 Voice PSTN Line Configuration.pdf
    http://www.ezvoip.ca/ezshare/SPA3102 Voice Line 1 Configuration.pdf
    http://www.ezvoip.ca/ezshare/3CX - PSTN Line Configuration Part 1.pdf
    http://www.ezvoip.ca/ezshare/3CX - PSTN Line Configuration Part 2.pdf
    Now some notes - you have given no information on your system beyond the fact that you are using an SPA3102, and your profile gives no geographical location. You really need to read this thread if you wish best results from this Forum:
    http://www.3cx.com/forums/viewtopic.php?t=93
    Now with that said... My setup is for North America and for me, because I must use their adapter, Vonage is my equivalent of a PSTN line, and behaves exactly the same with regards to the SAP3102. I cannot guarantee that my setup will work for you, and cannot assist unless you post a lot more information.
    With some additional tweaking of the call rules you could not tell, on my system, which calls are via VoIP (on 3CX) and which are via SPA/PSTN. If you need help with call rules let us know.
    If you ask me why I can't get the @#$% URLs to work, no clue :?: , work in progress.. FOR NOW PLEASE COPY AND PASTE IN YOUR BROWSER, FILES ARE THERE.
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Well after going around the configs i managed to set up phones to make outside Voip calls and to accept inbound calls from pstn line. The only thing that isnt working now is, im not able to dial from Voip to PSTN, outbound rules are set. Everything working except for that.
    22:47:23.375|.\CallTarget.cpp(449)|Trace5|CallManager|CT_Lines::Invite:Rule (Linksys): Placing call to line 10003@L:2@C:2b to reach 912299381
    22:47:23.421|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 404 tid=092dd3005241161e cseq=INVITE / 1 from(wire)
    22:47:23.421|Dialog.cxx(547)|Trace5|Resip|>>:Dialog::dispatch, ignoring stray response: SipResp: 404 tid=092dd3005241161e cseq=INVITE / 1 from(wire)
    22:47:23.421|ClientInviteSession.cxx(701)|Trace5|Resip|>>:Failure: error response: SipResp: 404 tid=092dd3005241161e cseq=INVITE / 1 from(wire)
    22:47:23.421|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAC_Start -> InviteSession::Terminated
    22:47:23.421|.\ISHandler.cpp(39)|Trace5|CallControl|ISHandler::eek:nFailure:Failure: cis=302;rl=SIP/2.0 404 Not Found
    22:47:23.421|.\Call.cpp(180)|Trace5|CallControl|CallLegImpl::eek:nFailure:Call to 10003@L:2@C:2b is failed, reason: Not Found
    22:47:23.421|.\ISHandler.cpp(100)|Trace5|CallControl|ISHandler::eek:nTerminated:Terminated: is=302;reason=Failure;rl=SIP/2.0 404 Not Found
    22:47:23.421|.\CallStrategies.cpp(781)|Trace5|CallManager|StratInOut::eek:nCancel:InOut: got Cancel from 10003@L:2@C:2b
    22:47:23.421|.\CallTarget.cpp(466)|Trace5|CallManager|CT_Lines::failed:Line 10003@L:2@C:2b doesn't accept the call, reason SIP/2.0 404 Not Found
    22:47:23.421|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: OnHook; DN 10003
    22:47:23.421|.\CallTarget.cpp(374)|Trace5|CallManager|CT_Lines::selectNextTarget:Select new line for outbound call
    22:47:23.421|.\CallTarget.cpp(412)|Trace5|CallManager|CT_Lines::selectNextTarget:No outbound line has been found
    22:47:23.421|.\CallTarget.cpp(472)|Trace5|CallManager|CT_Lines::failed:Breaking the call
    22:47:23.421|.\CallStrategies.cpp(811)|Log2|CallManager|StratInOut::eek:nCancel:[CM104008] Call(43): Call from Ext.100 to 912299381 terminated; cause: 404 Not Found; from IP:10.20.30.241
    22:47:23.421|.\CallConf.cpp(394)|Log2|CallControl|CallConf::Rejected:[CM103005] Call(43) is rejected: Not Found
    22:47:23.421|ServerInviteSession.cxx(384)|Trace5|Resip|>>:UAS_EarlyOffer: reject(404)
    22:47:23.421|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(299) sends SIP/2.0 404 Not Found
    22:47:23.421|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyOffer -> InviteSession::Terminated
    22:47:23.421|.\ISHandler.cpp(101)|Trace5|CallControl|ISHandler::eek:nTerminated:Terminated: is=299;reason=Ended
    22:47:23.421|.\Call.cpp(345)|Trace5|CallControl|CallLegImpl::eek:nEnded:Leg.onEnded 100@L:1@C:2b got zero msg
    22:47:23.421|.\CallStrategies.cpp(734)|Trace5|CallManager|StratInOut::eek:nHangUp:InOut: got Hang-Up from 100@L:1@C:2b
    22:47:23.421|.\CallConf.cpp(514)|Trace5|CallControl|CallConf::~CallConf:Destroying call 43
    22:47:23.437|.\CallStrategies.cpp(908)|Trace5|CallManager|StratInOut::~StratInOut:InOut: strategy is terminated
    22:47:23.437|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: OnHook; DN 100
    22:47:23.437|.\Call.cpp(1403)|Trace5|CallControl|CallLegImpl::~CallLegImpl:Leg 100@L:1@C:2b is destroyed
    22:47:23.437|.\Call.cpp(1403)|Trace5|CallControl|CallLegImpl::~CallLegImpl:Leg 10003@L:2@C:2b is destroyed
    Thks
  7. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I have never got it to work myself. And since 3CX happily uses the PSTN Line setup to both make and receive PSTN calls (the Line 1 / VoIP not required) I instead use Line 1 as an extra analog adapter for my internal extensions. If your setup is anywhere close to mine, just try the SPA with the PSTN Tab filled only.
  8. Anonymous
    Anonymous Guest
    There is a reasonable guide for this on the internet somewhere :).
  9. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Thanks alot, everything working now, inbound or outbound calls through VoIp or PSTN working great. Thanks once more :D
