Configure 3CX for Engin
Discussion in 'Android' started by Ollep, Feb 20, 2013.
  1. Ollep
    Feb 20, 2013
    Just installed 3CX on my Galaxy S I9000, and I have engin account for landlines.
    Tried a few configurations but 3CX stays with the "Not Registered" message.
    Connection & Service provider;
    ISP is Telstra Bigpond Cable;
    (BigPond Elite Liberty* (200GB) – Cable – Cable Modem, LAN Hubs and a Belkin router)
    I might have wrong "Name" account name and Display name (if it have any relevance)
    can I delete the account on the phone and start over?
    Cheers
    Olle...
  2. Ollep
    Feb 20, 2013
    I got these settings recommendations from Engin;
    It doesn't seem to match the options I have on the Galaxy though?
    The VoIP username: 075630xxxx
    The VoIP password: Ol1xxxxx
    The Authentication username: 075630xxxx
    The engin proxy: byo.engin.com.au
    The engin Outbound proxy: byo.engin.com.au
    The registration Time Out: 900sec
    Cheers
    Olle...
  3. leejor
    10,360
    226
    I would go with whatever settings they have given you. Some settings names may not quite match up, so you'll have to try a few things. You can either delete a current profile, or create a second, or third with "other" settings. Only one can be active at a time.
