- Joined
- Nov 8, 2012
- Messages
- 5
- Reaction score
- 0
Hello all, I am writing a C++ command line program to phrase the log files. For testing I just ran the visual .exe, but I need to do this as part of a scheduled task. this is where I have ran into the problem, when I call 3cxLogViewer.exe command line, I get a error telling me that I need a bldef and blrec files, but I can not find any documentation of what these files need to contain or the format. The closest thing that I can find is http://www.3cx.com/blog/docs/3cx-log-viewer/ and it just said that they are needed.
So my question is, what do these file need to contain and is there any reference saying what the format/options are?
Any help would be great!
P.S.
I looked at the manual and it was not help.
Thanks.
P.S.
Thanks.
