Configure break times.. is that Lunch or Away?
Discussion in '3CX Phone System - General' started by Chib@voip, Mar 3, 2016.
  1. Chib@voip
    Feb 25, 2016
    21
    If an extension has some Break-Times configured,
    and you check the box at: Automatically change extension profile based on time of day
    would you have to set the Forwarding rules under Lunch or under Away?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    77
    Checking the "Automatically change extension profile based on time of day" option will, depending on the time schedule you set right above it, will change the Extension Profile to "Away" and "Do no Disturb". While the Extension is in that status (and registered), it should follow the forwarding rules set for the profile it is in.
  3. Chib@voip
    Feb 25, 2016
    21
    Ok.
    I thought it was related to Lunchtime, as it was based on the time of day. But of course a break can mean anytime during the day, not just lunch time.
    So that means Lunch still need to be set manualy?
  4. NickD_3CX
    Jun 2, 2014
    1,338
    77
    Yes, the "Lunch" and "Business Trip" statuses must be set manually if you want to use them. They also have one more use. When you manually set an Extension to one of those 2 statuses, the scheduled-based status switching will stop until you set the status back to one of the other 3.
    The means that if you have e.g. "Business Trip" selected, that extension will stop switching between "Available", "Away" and "Out of Office" until you manually switch back to one of them.
    Also FYI, you can change the names of these 2 statuses from Settings -> PBX -> General tab.
