Configure CDR
Discussion in '3CX Phone System - General' started by vpage, Aug 20, 2017.
  1. vpage
    Mar 14, 2011
    7
    Is it possible in the generated cdr file about the call to add the ip address from which the call was made?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    i do not believe so from within the application itself.
  3. leejor
    11,129
    330
    If you are referring to incoming trunk calls, unless some callers are using direct SIP, then a log would reflect the IP of your VoIP provider. Perhaps you can provide additional information about what you are trying to achieve.
  4. vpage
    Mar 14, 2011
    7
    There is an internal number (Extension) that are registered and calling from external ip addresses. I would like to see what external ip address was a call
