Configure HandyTone 286 for PSTN line
Discussion in '3CX Phone System - General' started by idnsolutions, Nov 22, 2011.
  1. idnsolutions
    Nov 21, 2011
    im planning to use grandstream HandyTone 286 to connect analogue PSTN line to my IP-PBX.
    i need help how to configure it
    11,095
    327
    Unfortunately, you can't use the 286 to connect 3CX to a PSTN line. The 286 is used to connect a telephone set to an IP server (FXS). For a PSTN line you will need a gateway (FXO). Grandstream makes a number of them. One of the more flexible is the Linksys/Cisco SPA3102. It contains both an FXO and an FXS in one device. This allows you bring one phone line into 3CX as a trunk, and also allows one regular telephone to act as an extension on the PBX.
