Configure Holiday's with IVR-Function
Discussion in 'Ideas' started by sbcom, Jan 3, 2018.
Configure Holiday's with IVR-Function 5 5 5votes
5/5, 5 votes
  1. sbcom
    Jan 14, 2015
    9
    i think its important that we can configure some "Holiday's" that not only a special WAV-File is played ... it will be a nice (and important) feature that we can link a holiday with an IVR that we make for this day ... for example a customer has closed his office for internal training 2 days and would like to make a "Hotline" for emergency. in this cause we need a special WAV-File and also an IVR that will route the calls to an external mobilephone-number ... for example.
  2. Tifoso
    Oct 17, 2017
    58
    11
    +1
    this function would be great. because on holiday we have often special forwarding rule (to number or also to IVR)
  3. Brandan Hermo
    Jul 10, 2017
    39
    7
  4. kenttec
    Jul 29, 2016
    64
    18
    +1
    I've recently requested this since the Christmas holiday period is painful to say the least!!
  5. Mark Reynolds
    Nov 13, 2017
    8
    I am currently building a 24-7 solution for a multinational and during holiday periods they need the system to point to an IVR so that clients can continue to reach the Helpdesk and one other department. Until a holiday IVR option exists we are going to have to go with a manual workaround which is a time drain and error prone.
