Configure PBX with Dialogic Board
Discussion in '3CX Phone System - General' started by azia, Nov 9, 2008.
  1. azia
    Nov 9, 2008
    7
    Hello!
    I have 2 computers on same lan with windows xp on both systems. I have dialogic d/4pci card is installed on Computer B and 3Cx server installed on my Computer A. I would like to add PSTN line on 3Cx server there for Dialogic D/4Pci card installed. I am trying to configure/add PSTN line but 3Cx showing me all lines are down and i dont know how to connect my Computer A (3Cx) with Computer B (Dialogic Card)
    or
    I have no problem to install Dialogic card on computer A but still 3Cx not connecting with Dialogic card.
    can any one help me please
    regards
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,889
    190
    You need to use one of the supported VoIP gateways as listed on our support page. You will find configuration guides there....
  3. azia
    Nov 9, 2008
    7
    Hello!
    Thanks for your reply. Most of the Voip gateway are expensive. Can you please tell me is "Edge-corE VG007 VoIP Adapter" work with 3Cx?
    regards
  4. Nick Galea
    Jun 6, 2006
    1,889
    190
    No, in fact voip gateways are much cheaper then Dialogic cards. A grandstream gateway starts at about $150, patton gateways at about $250....
    Never heard of the edge adapter you mentioned. Its not supported with 3CX sorry....
