Configure receipients of Back-up emails
Discussion in 'Ideas' started by jeroendebruijn, Dec 11, 2017.
  1. jeroendebruijn
    Nov 9, 2015
    35
    18
    I noticed the back-up email template is gone.
    Although i not per definition have the need to edit the contents of the email template, I certainly do have the need to enter multiple recipients for this specific e-mail, as more often then not, the client self want to receive a copy. And of course as service provider, we need to have a copy of that mail to.
    So either please bring the back-up template back (preferred)
    or make an field/option in the backup settings to add multiple receipients
