configure second network interface on Debian and 3cx
Discussion in '3CX Phone System - General' started by Jose Lara, Jul 7, 2017.
  1. Jose Lara
    Mar 16, 2017
    23
    I need to configure additional network interface on 3CX Debian version.
    the primary interface (this interface got Default Gateway) is for general use of the system, I need additional interface to configure the SIP Trunk. and this interface must need a static route to the SIP trunk provider network.
    can someone help me?
    best regards,
    Jose Lara
  2. SECOIT GmbH
    Apr 3, 2017
    66
    25
    Hi Jose,
    I believe this is what you are looking for: https://wiki.debian.org/NetworkFAQ
    It shows how to do a static IP config, hot to add static routes (note the "up"), etc.
    Please keep in mind the network setup should be completed before configuring 3CX.
  3. Jose Lara
    Mar 16, 2017
    23
    Hi Michael,
    When I Install the 3CX I can see the 2 network adapters, but the system only permit configure 1 (Primary network adapter) I will check now the Debian Wiki to verify if this can be my answer.
    thanks,
