Configure the Dialtone by 3CX(Provisioning)
Discussion in 'Ideas' started by timmbo, Sep 19, 2017.
Configure the Dialtone by 3CX(Provisioning) 5 5 4votes
5/5, 4 votes
  1. timmbo
    Aug 25, 2017
    98
    47
    i´m asking, why i can´t configure the Dialtone int the Provisioningmenu from the 3CX?
    So i´m useing right now the Yealink T58V and i hear the English or USA Dialingtone.
    My Language is German but my Dialtone should by for Austria, so i gotta go the the Webmenu from the T58V to set it to Austria(Österreich).
    Bye
    Timm
    ITW likes this.
  2. ITW
    ITW
    Sep 20, 2017
    22
  3. Silly English Kniggit
    Sep 13, 2017
    220
    89
    Agreed - within reason. Some of the options specified in the templates are just weird and have no reason to be there. Setting phones to USA tones is high on that list.
  4. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    230
    9
    are we any closer to being able to set the dial tone for our own country? If we hack the template, we get the obligatory "we don't support that" from the 3CX staff, and also from 3CX itself when it complains about using an unsupported template.
  5. Rhys Haskell
    Jul 30, 2018
    43
    Its easy enough to change the template back if you had any problems and 3CX would provide support if it was reverted to the original template.
