Configuring BLF in Windows Client
Discussion in 'Windows' started by rhys100, May 25, 2017.
  1. rhys100
    Apr 7, 2017
    24
    Some users can right click and config BLF, other users are greyed out. Any idea why this happens?
    Web management they can edit them.
    It may be because they are using v15 and we now have 15.5 installed?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    241
    12
    What type of license are you using? Windows client side BLF configuration only applies on Pro License on V15.5 . But you can still configure your extension's BLF through management console.
    Thank you
  3. rhys100
    Apr 7, 2017
    24
    ah that would be it. we had pro, but just changed to STD. Seems a bit strange that thats a pro feature.
  4. Marios Neophytou
    Mar 1, 2016
    241
    12
    That is how 3CX Licensing works. Follow this link for more info.
    Thank you
    #4 Marios Neophytou, May 25, 2017
