Configuring busy lamp fields in custom phone template
Discussion in '3CX Phone System - General' started by splicer12, Aug 19, 2009.
  1. splicer12
    Aug 19, 2009
    Good afternoon!
    I have been setting up a phone system with 3CX Pro and a mix of Cisco 7940/7960 phones. So far the process has run smoothly, and I have even set up a phone template for the 7960 phones allowing 3cx to provision them successfully.
    What I would like to do is set up a second and third line on some of the 7960 phones. I understand that the template does not support separate authentication or names for additional lines, but I was hoping that if I made the authentication ID and password the same for both lines (simply changing extention and SIP ID) I could bypass that problem. That way, I could simply add the second extension in the BLF list for the primary extension and have it map both extensions to one phone. However, I have run into the following snag: when I try to update the provisioning for the primary extension, it gives me an "Unknown variable %%blf1%% in template" error. Below is a copy of my phone template. What am I doing wrong?
    Code:
    <?xml version="1.0"?>
    <doc xmlns:tcx="http://www.3cx.com">
      <header>
        <type>phone-template</type>
        <version>12.8</version>
        <time>2009-08-17 13:30:00</time>
        <name>Cisco 7960G</name>
        <url>http://www.cisco.com</url>
        <description>Cisco 7960G IP Phone</description>
      </header>
      <data>
        <device>
          <type>phone</type>
    	    <!-- Friendly Name -->
          <field name="Name">Cisco 7960G</field>
      <deviceconfig filename="SIP%%mac_address%%.cnf">
    <![CDATA[
    # SIP Phone.cnf
    # Phone settings
    phone_label: "%%extension_first_name%% "
    # Line 1 Settings
    line1_name: "%%extension_number%%"                     				; Line 1 Extension\User ID
    line1_displayname: "%%extension_first_name%% %%extension_last_name%%"           ; Line 1 Display Name
    line1_shortname: "Line 1"							; Line 1 Short Name
    line1_authname: "%%extension_auth_id%%"         				; Line 1 Registration Authentication
    line1_password: "%%extension_auth_pw%%"         				; Line 1 Registration Password
    proxy1_address: %%pbx_ip%%
    proxy1_port: 5060
    # Line 2 Settings
    {IF blf1}
    line2_name: "%%blf1%%"                     					; Line 2 Extension\User ID
    line2_displayname: "%%extension_first_name%% %%extension_last_name%%"           ; Line 2 Display Name
    line2_shortname: "Line 2"							; Line 2 Short Name
    line2_authname: "%%blf1%%"         						; Line 2 Registration Authentication
    line2_password: "%%extension_auth_pw%%"         				; Line 2 Registration Password
    {ELSE}
    line2_name: ""                     						; Line 2 Extension\User ID
    line2_displayname: ""         							; Line 2 Display Name
    line2_shortname: ""								; Line 2 Short Name
    line2_authname: ""         							; Line 2 Registration Authentication
    line2_password: ""     				    				; Line 2 Registration Password
    {ENDIF}
    proxy2_address: %%pbx_ip%%
    proxy2_port: 5060
    # Line 3 Settings
    {IF blf2}
    line3_name: "%%blf2%%"                          				; Line 3 Extension\User ID
    line3_displayname: "%%extension_first_name%% %%extension_last_name%%"           ; Line 3 Display Name
    line3_shortname: "Line 3"							; Line 3 Short Name
    line3_authname: "%%blf2%%"         						; Line 3 Registration Authentication
    line3_password: "%%extension_auth_pw%%"         				; Line 3 Registration Password
    {ELSE}
    line3_name: ""                     						; Line 3 Extension\User ID
    line3_displayname: ""         							; Line 3 Display Name
    line3_shortname: ""								; Line 3 Short Name
    line3_authname: ""         							; Line 3 Registration Authentication
    line3_password: ""     				    				; Line 3 Registration Password
    {ENDIF}
    proxy3_address: %%pbx_ip%%
    proxy3_port: 5060
    # Line 4 Settings
    line4_name: "" 							                ; Line 4 Extension\User ID
    line4_displayname: ""           						; Line 4 Display Name
    line4_shortname: "Line 4"							; Line 4 Short Name
    line4_authname: ""         							; Line 4 Registration Authentication
    line4_password: ""         							; Line 4 Registration Password
    proxy4_address: %%pbx_ip%%
    proxy4_port: 5060
    # Line 5 Settings
    line5_name: ""                     						; Line 5 Extension\User ID
    line5_displayname: ""           						; Line 5 Display Name
    line5_shortname: "Line 5"							; Line 5 Short Name
    line5_authname: ""         							; Line 5 Registration Authentication
    line5_password: ""         							; Line 5 Registration Password
    proxy5_address: %%pbx_ip%%
    proxy5_port: 5060
    # Line 6 Settings
    line6_name: ""                          					; Line 6 Extension\User ID
    line6_displayname: ""                   					; Line 6 Display Name
    line6_authname: ""         							; Line 6 Registration Authentication
    line6_password: ""         							; Line 6 Registration Password
    proxy6_address: %%pbx_ip%%
    proxy6_port: 5060
       </deviceconfig>
       </device>
    </data>
    </doc>
