Configuring FreeSWITCH as a voice provider
Discussion in '3CX Phone System - General' started by bmacdbacks, Apr 1, 2011.
  1. bmacdbacks
    Apr 1, 2011
    I need 3cx to interface to an existing FreeSWITCH pbx, at the moment I'm able to place/answer calls from 3cx to FreeSWITCH but calls coming from FreeSWITCH fail I believe because there's a mismatch somewhere in the SIP invite the following is captured from 3cx when a call is placed from FreeSWITCH->3cx
    10:47:16.165 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:8999@157.181.0.1 SIP/2.0
    Via: SIP/2.0/UDP 157.181.0.2;rport=5060;branch=z9hG4bK9D23B9XyjKjUB
    Max-Forwards: 69
    Contact: <sip:gw+Raptor2@157.181.0.2:5060;transport=udp;gw=Raptor2>
    To: <sip:8999@157.181.0.1>
    From: "8000"<sip:Raptor2@157.181.0.1:5060;transport=udp>;tag=t5Dc9g1N15U1N
    Call-ID: 12263766-d722-122e-9bbb-c7df350ec555
    CSeq: 10502053 INVITE
    Expires: 6000
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, UPDATE, INFO, REGISTER, REFER, NOTIFY, PUBLISH, SUBSCRIBE
    Proxy-Authorization: Digest username="Raptor2",realm="3CXPhoneSystem",nonce="414d535c03a6929413:0be63593de9b6f9bb4557f7c48f674c7",algorithm=MD5,uri="sip:8999@157.181.0.1",response="1bf6811b656aa59538eff7d90ed97c77"
    Supported: timer, precondition, path, replaces
    User-Agent: FreeSWITCH-mod_sofia/1.0.head-git-
    Allow-Events: talk, hold, presence, dialog, line-seize, call-info, sla, include-session-description, presence.winfo, message-summary, refer
    Content-Length: 0
    Remote-Party-ID: "8000" <sip:8000@157.181.0.1:5060>;party=calling;screen=yes;privacy=off
    X-FS-Support: update_display
    Basically the VOIP provider is set to Raptor2, with IP of 157.181.0.2 and again this works on the way out but not into 3cx, but it looks like the info needed to allow the call through is present in the message maybe just in the wrong location I've been looking through Source Id under Edit Voip Provider to see if I can have it pull the (Raptor2 and 157.181.0.) out correctly but have been unsuccessful, any help with this is greatly appreciated.
  2. willow
    willow Member
    Mar 1, 2011
    471
    Did you add the incoming routes for each station? ie a route for 100 to extension 100. this amy need to be done.
  3. bmacdbacks
    Apr 1, 2011
    I'm not sure that I've done this, I'm also not sure that this will help as the call is being rejected because authentication fails not because it wasn't routed. I'm willing to do this if it will help, where is it done at.
  4. bmacdbacks
    Apr 1, 2011
    found solution using settings from the following guide
    http://blog.skinkers.com/wp-content/uploads/2011/02/Integrating-Microsoft-Lync-2010-and-3CX-Phonesystem-using-Freeswitch.pdf
  5. willow
    willow Member
    Mar 1, 2011
    471
    perfect. good job.
