Configuring Grandstream HT502
Discussion in '3CX Phone System - General' started by dgruehn, Feb 26, 2009.
  1. dgruehn
    Feb 22, 2009
    6
    I'm using Broadvoice for VOIP and need to install their supplied Grandstream HT502 Phone Adapter to set up an extension for my Plantronics Calisto analog phone and headset. Has anyone successfully configured the HT502 as an extension in 3CX v7?
    Any help is greatly appreciated.
  2. danielbo
    Apr 17, 2008
    20
    I have a Grandstream HT502 and would like to get it set up to use with 3CX, does anyone have a working setup that I could have?
    Thanks in advance,
    danielbo
  3. SonnyPeas
    Apr 18, 2017
    19
    Set it up as a fax ata on 3cx, and it says not registered on grandstream so at a loss of what to do here
  4. leejor
    11,113
    329
