Configuring Linksys 3102 for 3CX Phone System
Discussion in '3CX Phone System - General' started by gerontas, Apr 7, 2013.
  1. gerontas
    Apr 4, 2013
    Ι follow the instructions (http: //www.3cx.com/voip-gateways/linksys-3102/) - NO LONGER AVAILABLE that parameterize the "Linksys 3102".
    I have not understand , how to parameterize the 3CX Phone to my PC.
    Can someone help.
    Thanks in advance.
    :oops:
    11,277
    360
    I'm not sure what you are asking. Are you having a problem with the 3CX Phone, or provisioning the ATA portion of the 3102?
    If it's the ATA...
    You are going to have to do it manually.
    Get the PSTN portion working first.
    Pay attention to the ports of each device.
    Post back once you've given it a go and some settings can be "tweaked" to allow both parts of the 3102 to work with 3CX.
