Configuring linksys phone to "out of office" connection
Discussion in '3CX Phone System - General' started by packy, Sep 19, 2008.
  1. packy
    Sep 19, 2008
    Hi everybody...
    I configured a 3cx phone system on a 2003 server with all needed port open; with 3cx client I can receive and make call from remote host (not in lan) to internal client.
    But if I use a Linksys SPA921 phone the internal doesn't result connect.
    How can I configure a linksys phone to "out of office" connection like 3cx client?
    Sorry for my english...
    Thanks,
    Packy
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello and welcome
    just open 5060 udp and tcp in your 3CX
    use stun server on both server and spa
    I have 942 works fine as remote phone
  3. packy
    Sep 19, 2008
    Hello amygoda.. thanks for your reply...
    How can I configure STUN server on SPA phone?
    Thanks!
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    http://xxx.xxx.xxx.xxx/admin/advanced
    sip tap
    STUN Enable: yes STUN Test Enable: no
    STUN Server: fwd stun or any stun server
  5. Sirk
    Sep 26, 2008
    12
    Hi Amygoda,
    I have the same problem too. I'm using SPA941 as my external extension to connect on our 3CX Server then set it up to STUN Server. It won't register on our 3CX Server.
    This is the message I got in the Server status.
    StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.100:5060
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    You could need set NAT Mapping Enable: to yes in each ext
  7. Sirk
    Sep 26, 2008
    12
    Ok. I'll set my SPA941 External Extension to NAT Mapping Enable = Yes.
  8. Sirk
    Sep 26, 2008
    12
    Hi Amygoda,
    Do i need to set EXT RTP Port Min: under SIP tab from my SPA941?How about NAT Keep Alive Enable: under Ext 1 tab?Do I need it to set to Yes?How about Outbound Proxy under Ext 1 tab?Do I still need to put our Static IP in our 3CX Server?
    Need your help pls.
  9. amygoda
    amygoda Member
    Sep 18, 2006
    436
    You do not need to do any of them
    what you see in
    info tab :phone status :External IP:
  10. Sirk
    Sep 26, 2008
    12
    I still don't have RTP Packets on the Phone Status.
  11. Sirk
    Sep 26, 2008
    12
    Under Subscriber Information, Do I need Use Auth ID = Yes?And enter the Auth ID?
  12. Sirk
    Sep 26, 2008
    12
    Hi Amygoda,
    I followed your instruction but still I don't have a connection from our External Extension.
  13. amygoda
    amygoda Member
    Sep 18, 2006
    436
    No you do not need
    You did not ansower me
    what you see in info tab :phone status :External IP:
    I have 921,941,942,962
    And grandstream 2000, 2020,bt102
    All are connected externally without any problem
    And the tip was only using stun server
  14. Sirk
    Sep 26, 2008
    12
    I got it registered without using NAT Mapping. But the problem rightnow, I can't call our external extension but the external extension can make an inbound call to our internal extension. I can hear the voice of our external ext but the caller can't hear my voice. I think its one way audio.
  15. amygoda
    amygoda Member
    Sep 18, 2006
    436
    and one way audio means nat
    the solution: stun server
  16. Sirk
    Sep 26, 2008
    12
    I don't have RTP Packets on Info tab. Why is that?
  17. Sirk
    Sep 26, 2008
    12
    Do I have to enable NAT Mapping on my SPA941 SIP tab? Stun server options on the 3CX?
  18. galal202
    galal202 New Member
    Jun 23, 2008
    235
    yes you have
    use fwd stun on both
  19. Sirk
    Sep 26, 2008
    12
    I already setup my Stun Server = stun.3cx.com under SIP tab on my SPA941 external ext. I got it registered on our 3CX IP PBX after setting it up. But when I tried NAT Mapping Enable = yes under Ext 1 tab, the registration failed in the Phone Status under Info tab. Why is that?
    Thanks for the help.
