Configuring my firewall
Discussion in '3CX Phone System - General' started by tata2078, Dec 1, 2008.
  1. tata2078
    Nov 30, 2008
    Hello i'm using now the Free Edition of 3cx phone Systems. Please help me on my problem, I'm using xlite softphone to call my friends computer he is using xlite softphone also but i can hear his voice, but the problem he can't hear my voice, please help me on this matter.
    The configuration of my friends computer on his Xlite softphone is:
    Display Name : 1234
    Username : 1234
    Password : 1234
    Auth Name : 1234
    Domain : xxx.xxx.xxx.xx -> it my IP Address only.
    I open the ports in my Router:
    My Router is Edimax Dual Wan Router:
    Port forwarding:
    Enable:Check
    Private IP - Type - Port Range - Wan Port
    192.168.2.xxx - TCP+UDP - 10000-20000 - Wan2
    192.168.2.xxx - TCP+UDP - 9000-9015 - Wan2
    192.168.2.xxx - UDP - 5060 - Wan2
    192.168.2.xxx - TCP - 5090 - Wan2
    192.168.2.xxx - TCP+UDP - 5480-5485 - Wan2
    Vertual Server
    Enable:Check
    Private IP - Private Port - Type - Public Port - Wan Port
    192.168.2.xxx - 5060 - TCP+UDP - 5060 - Wan2
    192.168.2.xxx - 5090 - TCP+UDP - 5090 - Wan2
    192.168.2.xxx - 5480 - TCP+UDP - 5485 - Wan2
    Please Help me on this...
    Tata
  2. tata2078
    Nov 30, 2008
    Re: Can't hear a sound on my client Softphone
    Thanks for not replying on me.
    by the way i solve it on my own, i got the problem on port forwarding.
    UDP 5060
    UDP 10000-20000
    and now we can talk to my friends xlite softphone, with clear voice quality.
    but dont forget the STUN on your configuration for the good voice quality.
    STUN: stun.3cx.com
    If you find my problem was helpful to yours, Please dont hesitate to reply on me on this messages.
    Thanks.
    Tata
