Configuring Patton Smart Node
Discussion in '3CX Phone System - General' started by silentfun, Jan 23, 2008.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    On the 3CX side is a page with the title "Configuring Patton Smart Node "
    where i found this
    where can i find this button? Click the “Generate config file” button.
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    This function is not included in the free version.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,887
    190
    It is included. 3CX Phone System Free edition has a button to generate the Patton config file
    Just follow the wizard when you create a PSTN gateway. On the last page there is the create configuration button at the bottom
  4. matthijsolislagers
    140
    My mistake.. Of course it is.
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Gateway Created
    HOME | LOGOUT
    Lines 10006 to 10009 have been created for xx
    You will need to enter these settings into the VOIP Gateway:
    Proxy server IP or FQDN: 85.88.25.24:5060
    Line 10006
    Internal number: 10006
    Authentication ID: 10006
    Authentication Password: 10006
    Line 10007
    Internal number: 10007
    Authentication ID: 10007
    Authentication Password: 10007
    Line 10008
    Internal number: 10008
    Authentication ID: 10008
    Authentication Password: 10008
    Line 10009
    Internal number: 10009
    Authentication ID: 10009
    Authentication Password: 10009
    For a detailed description how to do this for popular gateways
    Patton SmartNode 4960
    Configuring the Patton gateway to receive Fax calls
    GrandStream HandyTone 488
    Audiocodes MP-114 & MP-118 (Recommended)
    Patton Smart Node – 4638 (Recommended)
    Micronet SP 5050, 5052, 5054
    GrandStream GXW-4104 (Recommended)
    LinkSys SPA-3102
    Patton SmartNode 4112/4114
    Clipcomm CG410
    SIPURA SPA-3000
    this is my first time gateway until now i have had only voip providers and did from didx.net
    i have not found the button.
    i use 3CX Phone System Version5.0.3790.0 with 3CXPSSBFREE Licence
    and patton 4552 (the log above is from other patton but also no button on.)
    Andy
  6. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Andy, if you've changed the default settings for any reason, the button disappears it seems. (I'm in the middle of doing exactly the same - I think Patton must have releaseed a shipment!)
  7. silentfun
    silentfun Member
    Dec 11, 2006
    364
    what does this mean ?
    i toght i have not changed and i tested it some times - atm the patton is connectet and green in 3cx but i have not hat the time to connect it to the isdn line - when i have done i test it again
    Andy
  8. tein
    Jan 21, 2008
    5
    Hello guys. I had the sam problem with Config button and the files. Today I found out what was the problem with mysterious Config button that dissapeard. You have to configure all the lines (on SN 4638 - 4 of them by default) for the Gateway. Only in this case you get Config button with Config file at the end! Grrrrrrr...
  9. Discovery Technology
    Apr 19, 2008
    278
    I found this too. The problem for us is that we were originally using only 3 x BRI ISDN services and it almost looks as though we'll need a fourth just to match the config file and Patton 4638 settings.
    What we did:
    1) followed the defualts, noticed the four ports that it sets up by default, saw the "create config file" button, followed the rest of the setps and got the gateway up and running.
    When testing inbound and outbound calls, as expected, every now and then the phone wouldn't ring which leads me to believe that it is looking for the missing fourth ISDN service.
    2) Went through the process again, this time only choosing 3 ports - no create config button
    3) Went thourgh the process again, this time selecting 4 ports by default, then uploaded the config file to the Patton and tested ok. I then removed the fourth virtual extension in 3CX, and removed the fourth SIP gateway in the Patton - the link between the two stopped working, so I reverted back to 1 for now and am contemplating an additional ISDN service.
    Can this fourth line be removed manually? Can the create config file button be shown for less ports than the default 4?
    This would be very handy...
    Thanks, Brendan
