Configuring Quintum Tenor to work with 3CX
Discussion in '3CX Phone System - General' started by doncoxy, Oct 9, 2007.
  1. doncoxy
    Oct 9, 2007
    Hello Budddies,
    I have just tried the 3CX trial Version and it works fine for all extensions,but i have a quintum tenor ASM200 gateway that i intend to use for PSTN call from the PBX and also recieve call from the PSTN to PBX.
    Can anybody help me with how to do this . :roll:
  2. ktikoft
    Jun 22, 2007
    59
    I have a DX2010 in the 3cx config
    Add a generic gateway
    No Registration
    Destination number in RequestURI amd Remote fields
    PBX delivers Audion
    Use IP contact to recoginise source
    Caller ID in From Field
    Called number in Request URI field
