Configuring Sangoma PRI
Discussion in '3CX Phone System - General' started by steveh, Mar 29, 2009.
  1. steveh
    Feb 19, 2009
    6
    I'm planning to order a SANGOMA A102 card for the 3cx setup with PSTN.
    This card have two PRI ports.
    When I start the configuration wizard for the card in "Add PSTN Gateway" i see the option to configure 1 port only.
    Does anyone knows if a two port SANGOMA card is supported? if so how do I configure it? do I simply create an addtional VOIP GW for the second port?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    You status just plan to order a SANGOMA A102 card for the 3cx. If not the budget issue, I would like to suggest you to order Patton SN496X instead. Since most success case are using Patton. And 3CX also recommended Patton as well.
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Did you read the 3CX documentation for the supported Sangoma cards?
    By the looks of things only the A200 and PRI cards are supported.
    http://www.3cx.com/voip-gateways/ - UPDATED LINK
  4. steveh
    Feb 19, 2009
    6
    Looking at 3cx configuration guides they do support Sangoma A101 T1/E1/J1
    I don't see the A102 there, this card have two E1 ports.
    I need to know if it is supported as well or should I get two A101 cards.
    I do have a budget problem so Sangoma card is failry less expensive.
