Configuring spa3102
Discussion in '3CX Phone System - General' started by rsng, Dec 9, 2008.
  1. rsng
    Dec 8, 2008
    I setup 3cx on a winxp machine and setup a linksys 3102 voip gateway following the gateway configuration guide. I added a outbound calling rule to route calls to extension 10000 (programmed for 3102). Inbound calls are working. However outbound calling gives not available. Can someone please post what settings on 3102 worked for them.
    Greatly appreciate.
    thanks.
  2. rsng
    Dec 8, 2008
    I followed the guide, but couldn't receive or make pstn calls.
    Then followed the http://www.3cx.com/forums/outbound-call-using-pstn-7771.html?highlight=3102 guide. Now outgoing calls are working, however incoming dont work. :cry:
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,578
    115
    Use these settings for now. They should work.
    Dial Plan : (S0<:XXXXXXXXX>) (not 10000 or 10070)
    VoIP-To-PSTN Gateway Setup
    Line 1 VoIP Caller DP: none
    VoIP Caller Default DP: none
    PSTN-To-VoIP Gateway Setup
    PSTN Ring Thru Line 1: No
    PSTN CID For VoIP CID: Yes
    FXO Timer Values (sec)
    VoIP Answer Delay: 0
    PSTN Answer Delay: 2
    Disconnect Tone: 425@-30,425@-30;2(.2/.2/1+2)
    International Control
    FXO Port Impedence: 600
    SPA To PSTN Gain: 0
    PSTN To SPA Gain: 0
  4. xu1688
    Jan 6, 2009
    13
    I am having the same inboud calling issue. After following your instruction the inbound calls are working fine but caller ID only show 10000 on 3CX soft phone.
    If I change "PSTN Answer Delay" from 2 to 3 or up, the inbound call will not work. The only problem is the caller ID is not showing at "PSTN Answer Delay" set to 2.
    After more test, I have found that If I am calling from landline the inbound call always working and showing correct coller ID even "PSTN Answer Delay" set to 6. But if I am calling from cell phone (T-Mobile) and I have to set the "PSTN Answer Delay" to 2 which Caller Id is not working.
    Please help.
    Thanks,
    Derrick
  5. ess
    ess New Member
    Jun 8, 2007
    133
    Derrick,
    The problem you are having is a problem with the way the SPA3102 communicates with 3cx. When you increase the Answer Delay, you allow for Caller ID to pass through. The call is actually noticed by the SPA3102 (check the status as you're calling). However, as it sends the caller id to 3cx, it sends some illegal characters. While 3cx used to still handle these characters, it does not anymore in these latest versions. So, the call is not recognized because of the illegal characters in the SIP header. For more information, look at this post:
    http://www.3cx.com/forums/problem-with-spa3102-passing-invalid-caller-id-names-8379.html
    For now, the only solution is just to keep that ring delay down so the Caller ID is not being passed.
  6. xu1688
    Jan 6, 2009
    13
    Do you have preferred VoIP Gateway which have all features are supported by 3CX?
    Thanks,
    Derrick
