Configuring the SPA303 Phone
Discussion in 'Windows' started by thereverend, Aug 12, 2011.
  1. thereverend
    thereverend New Member
    May 29, 2011
    100
    Can someone please help me by providing step by step directions to programming the SPA-303 to work with 3CX.. i can get into the web page to admin the phone but need to know what setting and where to put the 3CX server info..
    Please help thanks
  2. willow
    willow Member
    Mar 1, 2011
    471
    you will need to setup the sip server ip address, user name, id, password and that is the basics.
  3. thereverend
    May 29, 2011
    100
    I do not see anywhere to put he SERVER IP the screens do not show this and I DO have admin access. It is in SIP mode but can not find this.. Can you please tell me where to find it..
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    It is quite similar to old SPA-941 in settings (see manual provisioning) or new SPA-504 (again manual provisioning).
    Nothing specific. Just go to: http://<SPA-303_IP_address>/admin/advanced and configure the same way.
    regards
  5. thereverend
    May 29, 2011
    100
    I am not seeing any place for me to put the 3cx server address in.. Can you possibly provide a screen shot or two.. I also do not see anywhere to put the ID and PW for the account either..
  6. eagle2
    Apr 27, 2011
    1,083
    10
    I don't have available SPA-303 at present.
    You need to log as admin in advanced mode to see all the settings. Select Ext 1 tab.
    I'm attaching a screen-shot from SPA-502G - it is quite similar.
  7. thereverend
    May 29, 2011
    100
    Ok.. I got into the area and set the PROXY to my 3cx server IP and gave it an extension ID an PASSWORD but.. when the phone re boots its on a YELLOW status on the phone and when you try to make a call it says 404 FAILED. can you tell me why it is doing that>??? thanks
  8. thereverend
    May 29, 2011
    100
    Thank you everyone for the help. I got it.. there was a hidden field called PROXY OUTGOING that was not there till i hit the advanced tab... Thanks again everyone!
