Configuring VOIP Client with Australian provider
Discussion in 'Windows' started by the-waves, Sep 16, 2008.
  1. the-waves
    Sep 16, 2008
    5
    Hi all,
    I am currently trying to configure the Free VoIP client with an Australian SIP provider, I have been using MyNetFone but am keen to try ISPhone also. The problem is when I type in my account details the VoIP client simply says 'connecting' - but it never connects! Has anybody else had this problem?
  2. mickp
    Jun 9, 2008
    72
    It's a little difficult to say without seeing what settings you're using. Keep in mind that for use with 3cx most of the time people will configure extension number and pin by selecting "3cx phone system" in the authentication section. For non 3cx connections you would want to use the "SIP server / VoIP provider section. You would probably also need to ensure that you have stun enabled. stun.3cx.com is reliable.
    Mick.
