Confusing Status for IP Based trunks (non-registering)
Discussion in 'Ideas' started by dig1234, Dec 15, 2015.
  1. dig1234
    Jun 1, 2015
    75
    Under System Status>Port/Trunks
    Trunks which do not require registration are listed as green "Registered (idle)" even though they are not actually registered because no registration is necessary. This can cause confusion. Example that happened to us where the trunk was not functioning for any reason it still shows green "Registered (idle). Which is a false positive of functionality. Perhaps it can be listed simply as grey Idle or similar.
