Confusion about features between versions
Discussion in '3CX Phone System - General' started by aaroncliffe, Aug 27, 2012.
  1. aaroncliffe
    Aug 27, 2012
    Hi All,
    I dont know about the rest of you, but I'm confised as to what features are limited in the Mini and Small Bussiness editions of 3CX v11.
    I've read somewhere that the presence / BLF of a bridged 3CX is only availble in the pro / Enterprise versions. I think this may have been in v10 but for the life of me I cant confirm if its still the case in v11.
    Also searching the Web Reports. are we still able to search call recordings inthe mini and small bussiness editions?
    Aaron
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Best place for details is from the office in your area under the contact section of this website.
    Also http://www.3cx.com/phone-system/3CXPhoneSystem_brochure.pdf
    In v11 the mini and sb can not transmit presence info to myphone at another site.
    But it can receive info from an enterprise version.
    I am not sure you can do a blf across a bride...
