congiguration of sipgate.de?
Discussion in '3CX Phone System - General' started by rookie07, Aug 31, 2007.
  1. rookie07
    Aug 31, 2007
    5
    hallo,
    i'm from austria and trying to configure the 3cx breakfree version to communicate with sipgate.de for that i've created a new voip-connection with folowing settings:
    Registrar/Proxy: sipgate.de Port:5060
    Ausgehender Proxy: sipgate.de Port:5060
    STUN-Server:stun.sipgate.net Port:10000
    the support says that have to work fine...if i'm checking the status is says registered but not active (green symbol)
    the server-protocol says:
    15:21:53.343 StratInOut::eek:nHangUp [CM104007] Call(3): Call from Ln:10000@SipgateDE to 250 has been terminated by Ln:10000@SipgateDE; cause: CANCEL; from IP:217.10.79.9
    15:21:24.015 CallConf::eek:nIncoming [CM103002] Call(3): Incoming call from 004369915141302 (Ln:10000@SipgateDE) to sip:004918019955005813@sipgate.de
    15:21:24.000 MediaServerReporting::STUN [MS101003] Call(3) Ln:10000@SipgateDE: Possible firewall problem. Address mapping failed on STUN server 217.10.79.2:10000 for local address ":9004"
    can anyone help me with that?
    THANK YOU VERY MUCH (i'm desperated)!
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Been doing this quite a bit recently :)
    http://www.3cx.com/forums/viewtopic.php?t=1697&highlight=ports+sticky makes good reading. The ones highlighted in Green should be forwarded on router or equivalent (if I interpreted post correctly), this does work for me.
  3. rookie07
    Aug 31, 2007
    5
    still not working for incoming calls...
    hi mirzab,
    back from my vacacions i'm working on the 3cx-sipgate problem. with your help i could make it work for outgoing calls, but incomming calls still don't work.
    for testing purpose i've disabled completely the firewall of the lancom-router and der windows firewall an the machine where the 3cx-server is running. also the port forwarding (i've almost forwarded any port) should work.
    the grandstream 2000gpx was configured as good as i know.
    so when i'm calling from a mobile phone to the voip-telephone i get following server-log:
    15:22:59.328 StratInOut::eek:nHangUp [CM104007] Call(21): Call from Ln:10000@SipgateDE to 100 has been terminated by Ln:10000@SipgateDE; cause: CANCEL; from IP:217.10.79.9
    15:22:29.687 CallConf::eek:nIncoming [CM103002] Call(21): Incoming call from 004369915141302 (Ln:10000@SipgateDE) to sip:004918019955005813@sipgate.de
    15:22:29.687 MediaServerReporting::STUN [MS101003] Call(21) Ln:10000@SipgateDE: Possible firewall problem. Address mapping failed on STUN server 217.10.79.2:10000 for local address ":9040"
    seems that the call couldn'tbe routet or resolved in the wright way, for now i'm leaking a little bit of ideas which i could try, propably you have any suggestions?
    THANX!!!
  4. etm_ltd
    Nov 18, 2006
    69
    Hi rookie007,
    On my own, we use SIPGATE UK. We have dicided not to use the Stun.sipgate.net:10000
    It works very well
  5. rookie07
    Aug 31, 2007
    5
    still not working
    thanx for the hint,
    i've tested this yesterday with refering on the stun.3cx.com:3478 or leaving the text-field blank in the voip config of the 3cx system.
    i've done the same for the grandstream 2000gxp voip-telefone. i've also tried many combinations...
    it still seems that an incoming call is recognized corretcly be the 3cx system (log-file) than the call is forwarded to sipgate.de and there might happen anything wrong (what at the moment i'm not able to figgure out).
    the only thing i get is the voicemail of sipgate.de which is telling me that the at the moment i'm not available...
    unfortunately the sipgate-support can't help me with this... :cry:
  6. BAGLIETTODAVID
    Aug 22, 2007
    Change the following and see if it helps but before making any changes allways back up your data.
    Registrar/Proxy: sipgate.co.uk Registrar/Proxy Port 5060
    Outbound Proxy Hostname or IP: sipgate.co.uk Outbound Proxy Port (default is 5060) :5060
    STUN server Hostname or IP: stun.sipgate.net STUN server Port (default is 3478) : 3478
    Also check you have the following ports forwarded to your PC running 3CX
    Port 5060 - 5062
    Port 30000 - 30021
    Port 10000 - 10012
    Port 3478
    Port 9000 - 9499
    Make sure ther all set for in and out as I cant remember what all the ports do BUT it worked for me.
    Dave
  7. rookie07
    Aug 31, 2007
    5
    i think sipgate.de != sipgate.uk
    thank you very much for your hints, but i think the main theme is that i've got an account for sipgate.de, so perhaps the configuration differs a little bit from the british one.
    i've tried your setting before - unfurtantely the same effect (does'nt work)...
    thank you!
  8. etm_ltd
    Nov 18, 2006
    69
    Re: i think sipgate.de != sipgate.uk
    I think the problem might be from Sipgate.de.
    We have opened a free account for buiness and see that 3Cx is registered to them but inbound calls never reach3CX PS.
    Still searching.....
  9. rookie07
    Aug 31, 2007
    5
    yes, this is the same phenomenon i've found out... i'm absolutely with you, i think the problem is sipgate.DE
    greetings!
