Connect 2 PSTN lines
Discussion in '3CX Phone System - General' started by webactive, Apr 10, 2011.
  1. webactive
    Apr 10, 2011
    If I want to connect 2 PSTN lines in Australia to 3CX, and use 8 sip phones, with only 2 calls at once.
    Can I use the Paton 4020 series? Other suggestions?
    http://www.patton.com/products/pe_products.asp?category=315
    thanks
    Matt
  2. countrycomp
    Dec 2, 2008
    52
    No. The 4020 are for connecting FXS ports, i.e. standard telephones to a SIP server. You need FXO ports to connect your PSTN lines to a SIP server (3CX) . I use the Patton 4114 devices mostly but the 4112 (SN4112/JO/EUI ) would suit you with 2 FXO ports.
  3. smb1
    smb1 New Member
    Mar 18, 2009
    104
    +1 on the Patton 4112.
    Order them direct from dna.com.au for a good price.
