Connect a call to two phones?
Discussion in '3CX Phone System - General' started by russix, Jan 13, 2010.
  1. russix
    Jan 13, 2010
    I was curious if anyone knows if 3CX can programmtically initiate a call to one phone number and then ring/connect another number/extenision on the same call? I've briefly looked over the 3CX API and didn't see anything specific about this. This is similar to saying "Make two people call each other", but I want to server to be the initializer whenever an event is raised to do so.
    Thanks!
  2. comresource
    comresource Member
    May 22, 2009
    303
    This can be done with the HTTP API
    http://wiki.3cx.com/api/http-api
    Look at the Make Call option at bottom
