connect call
Discussion in 'Windows' started by jeremyn, Jul 1, 2008.
  1. jeremyn
    Mar 25, 2008
    42
    when making a call thru the voip client using a desk phone it plays a RVA saying "your call is being connected" is it possible to just start ringing the ext. rather than the user having to wait ? it's somewhat frustrating
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    YOu do not have a divertion in there somewhere, this typically sounds like you call one extension and it is diverted to the other.
    H.
  3. jeremyn
    Mar 25, 2008
    42
    no this is a direct call originated from the pc, but to be made with a desk phone, this is before the phone actualy calls the number called
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    Just so I understand it,
    You originate the call on the pc and use the phone to talk?
    That is some sort of routing really, what happens the call is handed to the phone and this divertion takes time, during which the message is played.
    You get the same message if you forward a call from phone to phone, not sure if you can turn the functionality off. But my guess is that instead of having a silence you better hearing a message.
    H.
  5. jeremyn
    Mar 25, 2008
    42
    it's just that it's about 5 seconds and I would think it takes less time to route the call
  6. Henk
    Henk Member
    Nov 13, 2007
    250
    That is possible how long the message is, something to try is to put a silent message there see what happens.
    Without a trace I really have no idea why it does that.
    H.
