connect to VOIP Provider
Discussion in '3CX Phone System - General' started by Roshen, Apr 17, 2009.
  1. Roshen
    Jan 16, 2009
    35
    Hi All
    Im trying to get the sip trunk working in our test 3CX server,
    the provider has sullpied me with the following info:
    Signalling IP address: 203.x.x.x
    Media IP address: 203.x.x.x
    Media Ports: 35000 - 40000
    Registration ID and Password
    5 DID numbers
    In the 3cx VOIP provider wizzard asks for
    SIP Server hostname or IP
    Outbound Proxy hostname or IP
    I have opend the ports required on the firewall and changed the port numbers in 3CX to correspond with the ports he's supplied.
    Could someone help with translating the signalling, media ip addresses (as the provider refers to)to the sip server, proxy (As 3CX refers to) terminoligy?
    Really appreciate the help-
    -Roshen
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Hi Roshen
    Are the signalling and Media IP addresses the same?
    Regards
    John
  3. ctsxiyou
    Apr 12, 2009
    7
    Yes , If not the same IP , maybe your provider does not support SIP.
  4. Roshen
    Jan 16, 2009
    35
    Hi Thanks for the reply guys -
    I used the signalling IP address in the 3CX, but fowareded media ports between the 3CX and the media server ip address.
    this seems to be working currently.
    Also i turned of support reinvites - this fixed a sepperate problem with transfering calls.
  5. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    Interesting. Glad you got it working. I have not seen any other providers with the Media Gateway setup.
