Connect with other IPPBX
Discussion in '3CX Phone System - General' started by commonlo, Nov 26, 2012.
  1. commonlo
    Nov 26, 2012
    Hi!
    Wondering if it is possible for 3CX to connect with other IP PBXs, says Grandstream GXE5208
  2. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    3cx has a "bridge" ability. But this is limited to other 3cx's unless you find a work around.
    It is an excellent feature though
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    I have connected 3CX with:
    - alcatel oxe , avaya ipoffice , cisco call manager , mitel icp 3300 , 3com nbx , wildix ,
    You must create a generic trunk , using trusted trunk viaip address
  4. aklawrence
    Dec 8, 2011
    13
    I have integrated it with Microsoft Lync 2010 by using the same trunking method. Depending on how many extensions, dialing plans, etc., it can get a bit messy from an administrative standpoint.
  5. commonlo
    Nov 26, 2012
    Thanks guys, I'll try.
  6. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    This can be achieved with the Bridge and or the Generic SIP Trunk/Voip Provider setup (this allows for Outbound rules). If it supports SIP you are most likely able to. The only one that gave us a major headache was a hosted system by T-Mobile in Germany but that worked too.
