Connecting 3CX to AT&T BIB SIP Trunks
Discussion in '3CX Phone System - General' started by rayfield, Mar 20, 2018.
  1. rayfield
    rayfield New Member
    May 4, 2010
    124
    I have a customer who already has a 3CX system and wants to connect it to an AT&T Business In a Box (BIB) SIP Trunk. I've seen some information on these forums about doing this, but the solutions mentioned made use of two NIC cards in the 3CX server. I would like to avoid that, if possible, and only use one NIC card in the 3CX server. The customer needs to keep all telephone traffic on the same network as his computer system (can't split telephone and data traffic into two networks).
    Since the data connection and the SIP connection are provided through two ethernet connections from AT&T's equipment, is it possible to use a dual-WAN router (such as a MikroTik router, programmed as such), to connect both connections (data and SIP/Voice) to the customer's LAN and the 3CX server (thus only using one NIC on the 3CX server)?
    If so, does anyone have some fairly specific information on how this might be configured?
    John Rayfield, Jr.
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    771
    118
    You are over thinking this. Two NICs is only for the 3CX system. The phones and the internal interface of 3CX can sit on the internal/data network. The 2nd NIC in the 3CX box is because SIP from AT&T is delivered over a separate interface. You might be able to talk AT&T into handing it off on the same interface (you used to before with the Cisco routers) but then you would be in an unsupported configuration and god help if you things don't work.
  3. rayfield
    rayfield New Member
    May 4, 2010
    124
    I understand about using two NICs. I don't want to have to deal with AT&T, trying to get them to do anything different than what they're used to doing. I thought it might be easier to set up a dual-wan router, but I suppose that two NICs might be easier, now that I'm thinking about it. I'll dig up your post about using dual NICs with AT&T and take a closer look at that.
    John
