Connecting my mobile remotley
Discussion in '3CX Phone System - General' started by GBond, Sep 7, 2015.
  1. GBond
    Nov 27, 2011
    12
    since I upgraded to Ver.14 I can not get my mobile to connect once I am off my local network
    it goes "On Hook" but just keeps saying its "connecting" I am using port 5061 as my default sip port on the PBX and think I have set up all the required firewalling etc & the 3cx tunnel but I just cant get it to work.(also the dns srv record)
    Can anyone give me a clue what I need to check?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    Have you upgraded the IOS 3CXPhone to version 14.
    Have you setup spilt DNS ? If so, does the IP address point to the firewall external IP address - http://www.3cx.com/docs/creating-fqdn-split-dns/
    You have reprovisioned your mobile by sending the welcome email and installed the config file
    Have you checked you have opened all the required ports - http://www.3cx.com/docs/firewall-router-configuration-voip/
    What is the result of the firewall checker ?
  3. leejor
    10,744
    281
    If it indicates "on-hook", then you are registered and should be able to make, and receive calls. The "connecting" is the Presence status and requires additional port(s) to be open.
    http://www.3cx.com/docs/3cx-phone-system-v14-ports/
