- Joined
- Apr 14, 2018
- Messages
- 183
- Reaction score
- 16
Dear Community,
Sorry if the question was asked before, but i could not found an answer with instructions detailed enough I can follow.
I am using Cloud based 3cx version
I have created an extension in 3cx that has a username and password. Does this mean I can connect via any sip phone and sip client (like Linphone or smth) using
- hostname.3xc.com
- username
- password
or do i need to create a separate SIP account for connecting my 3rd party sip phones?
For example, I want to connect using my Cisco SPA122. It is not listed as supported device. Therefore I can not do provisioning. When just using Username and Password from my extension, the registration fails. What username/password and other settings should I use to be able to register in 3cx? Can i just setup a sip account and add the phone by logging in into that account from my sip phone?
Any advice will be very appreciated.
Again I apologize for beginner-level questions, especially, if this has been addressed before.
thank you.
- hostname.3xc.com
- username
- password
thank you.
