connecting to 3cx web management console from a client
Discussion in '3CX Phone System - General' started by koshy_vimal, Feb 4, 2009.
  1. koshy_vimal
    Jan 13, 2009
    15
    Hi all,
    I have successfully installed and tested 3cx in both cassini and IIS environment. The problem is that I cannot connect to the 3CX web management console from a client when 3CX is installed on IIS. But it is possible using the cassini.
    For cassini - http:// ip_address:5481 - works
    for IIS - http://ip_address:1025/5480/5482, etc - does not work
    When I tried http://ip_address/management/ on IIS environment it gets connected successfully.
    I wanted to know if there is any port number that I can use to connect to 3cx in IIS.
  2. TweetyBear
    Nov 18, 2008
    hello
    you should try this :
    http://youripaddress/management/MainForm.wgx
    If you try to access it from your internal lan, you should place the ip of your server, if you want to connect it from outside of your local netword using a wan access, you should place the ip provided by your ISP with appropriate ports forwarding rules placed on your router.
    Here that way it works fine !!
    :p
  3. koshy_vimal
    Jan 13, 2009
    15
    yes it got connected that way. Thanks. But is there a way to get connected by using the port number ip_address:port number rather than using ip_address/management/....etc. ? which port number should i use?
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,445
    61
    Hi, Koshy
    Of course you can use a port - 80, no way to escape, http://ip_address:80/management/ :mrgreen:
    Ok, more about this problem IIS/Cassini you can find here (in fact, the whole topic there) I think it might be useful to clarify:
    http://www.3cx.com/forums/version-7-api-info-8155.html#p41585
    On XP running IIS, management, as IVR also, is a virtual directory.
    Regards
    vali
  5. koshy_vimal
    Jan 13, 2009
    15
    Thanks guys,
    Its working now.. I added /management after the ip address
