Connecting to a VOIP provider
Discussion in '3CX Phone System - General' started by William400, Aug 21, 2006.
  1. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    I have installed and configured most of my needs for a test setup. Impressive :)
    I am currently subscribed to a VOIP provider and have 1 number on which i can make and revice calls. For some reason the 3CX is reporting the VOIP line as not registered but the 3CX phone connects to the VOIP provider form the same machine.
    How can i debug the VOIP connection?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,004
    308
    Checking VOIP Provider line status
    Thank you for your feedback :D
    What provider are you using? Could you give us the URL?
    Which ports did you open on the internet facing firewall?
    Does the VOIP Provider line show up in the Line Status screen? What is the exact status it shows?
    Could you go to the server status screen, copy and paste the log and send it to support@3cx.com? With this info we can see whats going on.
    regards,
    Nick
  3. William400
    Aug 21, 2006
    1,005
    We are trying 2 provider, SIPgate and Phoneline (http://www.phoneline.com.mt).
    The 3CX server has full outbound access (All outbound as specified by ISA 2004 plus port 5060). Am I missing some other port? The 3CX phone on the same machine machines to register fine with these providers.
    The VOIP provider does appear as 'not registered'.
    The server status shows little info i can understand, however shall email this shortly.
    William
