Connecting to Cassini for call reports
Discussion in '3CX Phone System - General' started by mase2hot, Jan 6, 2011.
  1. mase2hot
    Aug 17, 2010
    38
    we have 3 seperate 3cx systems V9 around the country I'm alway being asked for call reports. I would like to be able to connect to Cassini and run scripts to get data in the way I want it. Is this possible? If so what are the connection parametres for this? I would use a program like toad if possible?
