Connecting to Siemens Gigaset
Discussion in 'Windows' started by William400, Jan 13, 2009.
  1. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    If you follow the Server Status of 3CX, is 3CX attempting to route the call to the expected IP for the base station?
    If you follow a capture can you see that the 3CX IP is sending an INVITE to the IP for the Siemens?
    If YES, does the Siemens send any traffic back?
