Connecting two gateway in different location over internet
Discussion in '3CX Phone System - General' started by virgel07, Oct 31, 2012.
  1. virgel07
    Jan 5, 2012
    21
    Good Day!
    Sir i just want to ask if it is possible, i want to connect two gateway via internet connection. I'm using Grandstream GXW4104 for my gateway and 3cx Phone System V.11 Free Edition. What i want is, if our customer call to our 1st office, it can be forwarded to our 2nd office in an extension line via internet connection. Our offices have their own telephone area code and it is a long distance call.
    Thanks in advance.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Re: Connecting two gateway in different location over intern
    You didn't quite give the whole picture. What is at the other office that you expect the other gateway to connect into?
    You should check with Grandstream on their website as they have some whitepapers and documentation about the various applications and scenarios by which their gateways can be used to extend lines.
  3. leejor
    11,263
    358
    If you are talking about having 3CX in one location (with it's own local gateway), and then connecting a remote gateway, in a second city/location, then generally, yes, it's possible. A lot will depend on the network set-up at each end (static IP?), and the options on the make of gateway you plan on using at the remote location.
    What you are trying to do is no different than a remote server hosted 3CX installation, with only the sets and a gateway located at the customer location.
    You will probably have some issues if you intend on continuing to run with the free edition.
  4. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    There are two ways that you could do this:-
    1. Use a VPN to the location where the remote gateway is based. It's likely that you will need to replace the router to do this at each end. The Draytek 2830 would work well. Make sure that quality of service is setup to prioritise voice over other traffic
    2. Connect the remote gateway directly to the Internet. To do this you will need to obtain additional IP addresses from your ISP, and connect the gateway one of these static IP addresses.
    I hope that helps
    Richard Crabb
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    It may be easier to use SIP Proxy manager if, or provision handsets at remote locations as external extensions. or AS you stated simply make a PTP using routers and provision handsets as on the LAN.
